shingabiss Posted June 30, 2023 Share Posted June 30, 2023 Hi All, I'm using Chief Architect X10. The automatic dimensioning tools, int and ext, seem to need a fair amount of 'cleanup' as the positionings aren't elegantly placed in a lot of instances. I wonder if I've got the default font settings for B size sheets set wrong or if this is just how the tool works in X10. Assuming the latter is true, is there any faster way of making the formatting better, rather than manually tweaking the spacings? Thanks. Scott Link to comment Share on other sites More sharing options...
Kbird1 Posted June 30, 2023 Share Posted June 30, 2023 On 6/30/2023 at 8:26 AM, shingabiss said: is there any faster way of making the formatting better, rather than manually tweaking the spacings? It can be a bit messy depending on your Settings as it uses the current Dimension Default in Use when you click the button/Icon plus the Automatic Setup > Exterior Settings , I am not 100% sure if X10 uses the same dialog or not? as I no longer have X10 installed ( post pics back if needed) I generally don't use auto interior dims and just use the Interior Dim Tool as needed.... for your Exterior separations try this tab........... 1 Link to comment Share on other sites More sharing options...
shingabiss Posted June 30, 2023 Author Share Posted June 30, 2023 Thank You. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted July 1, 2023 Share Posted July 1, 2023 17 hours ago, shingabiss said: Thank You. Happy to help if I can S. I appreciate the Thank You too, many don't bother these days... Mick. 2 Link to comment Share on other sites More sharing options...
