RobUSMC Posted June 4, 2023 Share Posted June 4, 2023 Has anyone else had the issue of when you zoom out using the perspective crop tool that you see your backdrop? This is a bath in the center of the home so no windows in this space to have any backdrop showing. Using X14 right now. Thanks Link to comment Share on other sites More sharing options...
MarkMc Posted June 4, 2023 Share Posted June 4, 2023 A quick test in just a single room structure does not show the issue. PTP Link to comment Share on other sites More sharing options...
RobUSMC Posted June 4, 2023 Author Share Posted June 4, 2023 Mark when you zoomed out with perspective tool did you rotate the view using the Move Camera with Mouse tool? That's when I get the issue. If I zoom straight back I don't Link to comment Share on other sites More sharing options...
MarkMc Posted June 4, 2023 Share Posted June 4, 2023 2 hours ago, RobUSMC said: view using the Move Camera with Mouse tool Used mouse with Orbit on, tried dolly using mouse, tried pan with mouse scroll to zoom. All the same. Think it might be something elsewhere in the plan? Here's the test plan Mirror.zip Link to comment Share on other sites More sharing options...
MarkMc Posted June 4, 2023 Share Posted June 4, 2023 You mentioned Perspective Crop, is that what you are using? May be the issue? ChiefArchitectPremierX14ReferenceManual-ConsiderationsforLegacyFiles 1. Perspective Crop Mode In Chief Architect X8 through X11, Perspective Crop Mode allowed older functionality governing zooming in cameras from Version X7 and prior to be preserved in saved cameras in legacy plans migrated forward. This deprecated tool has been removed from the program’s menu and toolbars in Version X12, although it can be migrated with legacy toolbars and hotkeys. Saved cameras in legacy plans with this behavior enabled may become distorted if you pan or zoom in the view. To permanently disable this behavior in a camera view and resolve the resulting distortion, select Window> Fill Window or press the F6 key. Link to comment Share on other sites More sharing options...
RobUSMC Posted June 4, 2023 Author Share Posted June 4, 2023 I increase the camaras field of view and turned off backdrop and seemed to fix it Link to comment Share on other sites More sharing options...
