How To Make Objects Stop Running Over Each other
Reu_Ari
Go to solution Solved by TeaTime,
Hi, When I downloaded the x15 update now all my objects don't stop when they meet each other.  For Example I used to be able to push a cabinet against the wall and it would stop.  Now it just continues to move through the wall.   This is the same for all objects.  Is there a option to make these "solid" again so that can't move through  each other?
  • Dermot changed the title to How To Make Objects Stop Running Over Each other
  • Solution
Sounds like Bumping/Pushing got turned off.
This wouldn't have anything to do with X15, but if you accidentally hit the F11 key on your keyboard, that'll certainly be the result.
Check the Edit menu, Snap Settings.
