CharlesVolz Posted 22 hours ago Share Posted 22 hours ago (edited) I thought I posted how I do it before, but I do not see it. So here are my notes. Base Baseboard Molding Shadow Gap Reveals or Reglets. The easiest way that I have found is to use room moldings. Easy to apply to a whole floor, a room and/or eliminate on walls as desired with CA's room molding control. I used the air gap material at first but prefer the look of just black color. Use moldings set 1/32 to 1/16 proud to inside of wall face to avoid 3D "Z-fighting". I suggest using a room molding polyline (one polyline with multiple stacked rectangular-shaped moldings) to keep the molding(s) out of the way while working. See Trim-Tex Z Shadow Bead tear away shadow bead. Edited 22 hours ago by CharlesVolz Link to comment Share on other sites More sharing options...
