GMcGee Posted May 9, 2023 Share Posted May 9, 2023 Is there a way to align a series of interior wall elevations at the same point/floor? It's difficult to tell from this photo, but the floor location of these two elevations are slightly off. I've tried drawing a line across the entire sheet so I can align 4 or more along the row, but they snap to just above or below the line of the first elevation. Grid Snaps is off. Link to comment Share on other sites More sharing options...
TeaTime Posted May 9, 2023 Share Posted May 9, 2023 Point to Point Move can locate the CAD within an Elevation view - but they have to be set to Plot Lines (it looks like yours are, but you might open the Layout Box specification to check). Draw a CAD Line across where you want their floors to align, then for each layout box, select and use Point to Point Move to move the lower corner of each view (Point A) down to the line (Point B). Link to comment Share on other sites More sharing options...
GMcGee Posted May 10, 2023 Author Share Posted May 10, 2023 Perfect, I got it to work. Thanks! Link to comment Share on other sites More sharing options...
