mrsmith Posted May 2, 2023 Share Posted May 2, 2023 I'm trying to simulate a barbed wire fence. I used a T-post for the newels and then a cable style panel. However, even if I set the railing height shorter, the cables still show up taller than the fence posts. Is it possible to modify the spacing on them or change the height of a fence panel from the library? Link to comment Share on other sites More sharing options...
TeaTime Posted May 2, 2023 Share Posted May 2, 2023 6 minutes ago, mrsmith said: Is it possible to modify the spacing on them Nope, they're a symbol object so when the panel is resized, they just stretch. 7 minutes ago, mrsmith said: or change the height of a fence panel from the library? On the Fence dialog under Newels/Balusters there's both Railing height and Newel height options to set the posts and panels to different heights. You'll probably need to create a custom panel symbol that more closely fits what you're after. Link to comment Share on other sites More sharing options...
