Dimensioning in 3d view
shingabiss
Go to solution Solved by DavidJPotter,
Hi All,
Is there such a thing as a dimension tool that can be used in 3d views to measure height (besides story pole in section shots)?  My workaround has been to make a slab, usually 12x12x n high to move around the 3d view as a 'measuring stick'.  This is clunky so I figured there's got to be a tool I'm not seeing.  Using X10 on a PC.
Thanks
