Adjacent walls of different types at 90° wrap strangely
ProPlan_2011
Go to solution Solved by Chrisb222,
It seems that 2 adjacent walls at 90°, brick-6 and siding-6, will have one side wrap incorrectly, depending on how they are drawn..
To demonstrate this, I created two simple 4-wall plans with the front wall brick-6 and the others siding-6 (attached).
If the walls are drawn counter clockwise, the 'left' side of the brick-6 wall will wrap correctly with the siding-6, but the wrap at the 'right' side will leave a gap that seems to be the thickness of the brick's air gap.
If the walls are drawn clockwise, the 'right' side of the brick-6 wall will wrap correctly with the siding-6, but the wrap at the 'left' side will leave a gap.
It seems the beginning of the wall drawn will wrap ok, but not the other end.
Or I'm missing something too obvious?
Wall bug.pdfFetching info...
