More Macro Help - If/else Statements?
MikeJG
Is it possible to have an if/else statement in a macro?
What I would like to do is have a door label macro that will give me a different result based on whether it is a double door or not.  (There are also a bunch of other applications for this that I'm thinking about).
For instance, the way we label doors around here a 3-0 swing door would be "D30".  However, as a double door it would be "2-D16".
So the statement would be something like:
If is_double_door = true then "2-D" width / 2
Else "D" width
If it can be done, what would the syntax look like?
Any help would be appreciated.
Else "D" width
case
  If is_double_door == "true"
    result = "2-D"+(width/2).to_s
  else
    result = "D"+width.to_s
end
result
Mike,try this:
case
  when is_double_door == "true"
    result = "2-D"+(width/2).round.to_s
  else
    result = "D"+width.round.to_s
end
result
"if" doesn't work within a "case".  The proper syntax is "when"
Of course for a 36" single door the above results in D36, not D30.  Likewise a pair of doors totalling 36" would result in 2-D18 not 2-D16.  To get the exact result you indicate would require using divmod(12) as per a previous exercise.
like this:
case
    w = (width/2).round.divmod(12)
    result = "2-D"+"#{w[0]}#{w[1].round}"
  else
    w = width.round.divmod(12)
    result = "D"+"#{w[0]}#{w[1].round}"
end
result
Joe,
The result was coming out "D30" regardless.of whether it was a double door or not.  I was determined to try to figure it out for myself, so I did some googling.  It turns out I had to remove the quotes from around "true" on the 2nd line so it reads now:
case
when is_double_door == true
else
end
result
Now it works!
Thanks again for taking the time to help!
