myrtsbnye Posted April 17, 2023 Share Posted April 17, 2023 Hello all, Is there a way to show this roof to wall waterfall type effect? I can do the roof and the wall separately but its the point at which the roof transitions to the wall. I can't seem to get a smooth transition. I appreciate any help offered. Link to comment Share on other sites More sharing options...
TeaTime Posted April 17, 2023 Share Posted April 17, 2023 I *think* this applies to X12 still ... but yeah, unfortunately you can't do it with Roof Planes alone even though that seems the most logical The highest a roof plane can pitch is 89 degrees, and boy it gets wonky when you try it. It's not the most elegant thing but Applying a CA-001 Shadow Board around the roof, you can set a 0" Eave Overhang and let the Shadowboard fill the exposed edge, set it's height enough to meet the siding of your new wall type that's defined to use the same roof material - and shadowbaord's thickness to the same thickness as the siding little tip: set the shadowboard's vertical offset to 1 and it'll create an angled edge on the top. Left at 0 it'll probably create a goofy gap Link to comment Share on other sites More sharing options...
