Newel post height and closed toe stringer on landing
carowe
I'm working on a house with 4 staircases that have railings near them as well and I have a couple questions on them.  On the staircase railings, I can uncheck the "rail passes over newel" and then set the height of the newels (pic 1).  How do I do the same thing so the railings in this loft (pic 3) match the staircase railings?  If you look at the specs in pic 2, there isn't a place to do that for straight railings and I can't set the height of the newels either.  Am I doing something wrong?  Also, how can I close the toe of a landing and put a molding under it to match the stringer without drawing a polyline solid thick enough to cover the overhang (which is what I did in pic 3)?
3.pdf
