carowe Posted April 11, 2023 Share Posted April 11, 2023 I'm working on a house with 4 staircases that have railings near them as well and I have a couple questions on them. On the staircase railings, I can uncheck the "rail passes over newel" and then set the height of the newels (pic 1). How do I do the same thing so the railings in this loft (pic 3) match the staircase railings? If you look at the specs in pic 2, there isn't a place to do that for straight railings and I can't set the height of the newels either. Am I doing something wrong? Also, how can I close the toe of a landing and put a molding under it to match the stringer without drawing a polyline solid thick enough to cover the overhang (which is what I did in pic 3)? 3.pdf Link to comment Share on other sites More sharing options...
DBCooper Posted April 11, 2023 Share Posted April 11, 2023 For the railing, go to the "rail style" and set it to "rail to post" instead of "post to rail". Then you can set the post height. Link to comment Share on other sites More sharing options...
carowe Posted April 12, 2023 Author Share Posted April 12, 2023 That was too easy! Thanks Link to comment Share on other sites More sharing options...
