deleted post
SkullMesaRanch
Go to solution Solved by Chrisb222,
  • Solution
1. This is not footing thickness it's wall thickness.
2. On the Structure panel of the Wall Specification Dialog, the wall between the kitchen and living room, and the short wall of the closet have Bearing Wall and Create Wall/Footing Below checked. The bedroom walls have Create Wall/Footing Below checked. Uncheck those.
3. As to the span or whether you need those bearing walls, that depends on your structural intents and goals. That's up to the designer to decide. Although it looks like you intend to use common trusses, in which case, no, 32' is not too far to span.
  • 1 year later...
