SkullMesaRanch Posted April 3, 2023 Share Posted April 3, 2023 deleted Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted April 3, 2023 Solution Share Posted April 3, 2023 1. This is not footing thickness it's wall thickness. 2. On the Structure panel of the Wall Specification Dialog, the wall between the kitchen and living room, and the short wall of the closet have Bearing Wall and Create Wall/Footing Below checked. The bedroom walls have Create Wall/Footing Below checked. Uncheck those. 3. As to the span or whether you need those bearing walls, that depends on your structural intents and goals. That's up to the designer to decide. Although it looks like you intend to use common trusses, in which case, no, 32' is not too far to span. 1 Link to comment Share on other sites More sharing options...
VegasFoundations Posted May 24, 2024 Share Posted May 24, 2024 Are there any threads or resources within ChiefTalk that users recommend for finding high-quality, reliable custom content to expand their design options within the software? Link to comment Share on other sites More sharing options...
