JavaMan Posted April 2, 2023 Share Posted April 2, 2023 I need a case opening w/ the small railing below (see photo of example). Apparently, the properties of door case opening w/ the "rail wall" don't work together. 4 hours later, I still don't get it. Help! Clark Stairs.pdfFetching info... Clark Plan VII- Stairs II.pdfFetching info... Link to comment Share on other sites More sharing options...
glennw Posted April 2, 2023 Share Posted April 2, 2023 Draw your cased opening the full width. Draw a section of railing close by and define it as No Room Definition. Drag the railing wall section into the cased opening. 1 Link to comment Share on other sites More sharing options...
JavaMan Posted April 2, 2023 Author Share Posted April 2, 2023 Glenn, Worked great. 10x better. Got one little issue w/ the floor open where the 1st stair is located. Otherwise, that No Room worked. Thank you, cliff Link to comment Share on other sites More sharing options...
JavaMan Posted April 3, 2023 Author Share Posted April 3, 2023 Thanks. Just got to cover the floor below the railing. Link to comment Share on other sites More sharing options...
