Foundation Building Under Interior Walls
OrinCrowder
Go to solution Solved by Doug_N,
Can't figure this out. Walls for two interior rooms - walk in closet and laundry/pantry combo - are extending through the floor. When I build the foundation it builds separate foundations under those rooms. Tried deleting and re-drawing with same result. Wall and room structure specs same as other rooms. Toggling "Build foundation below" on and off has no effect. Any ideas? Thank you.
  • Solution
Here is an example of a simple building with one of the interior walls being set to be load-bearing.
Pictured below, is the resulting automatic foundation generated.
I think this is why CA is creating walls and footings below some of your interior walls.
It may be also that those areas in your screen clip have a different floor level that is lower than the surrounding floor.
