DesignerAnnilee Posted March 24, 2023 Share Posted March 24, 2023 I'm using a template from a designer client, in X15. All of the room labels are showing double. When I double click the room label itself, it shows the room name then also the macro for room name, which, on the surface looks to be the problem, but it's greyed out and I cannot edit it. When I go into the defaults, it's only showing the macro. I'm clearly missing something, I've never seen this before. Is there somewhere else I can look to fix this? Help! Please and Thank you! Link to comment Share on other sites More sharing options...
DBCooper Posted March 24, 2023 Share Posted March 24, 2023 Any text you put in the room label defaults just gets added after the room name. So all you need to do is get rid of the %room.name% in your defaults and leave it blank. 1 Link to comment Share on other sites More sharing options...
DesignerAnnilee Posted March 24, 2023 Author Share Posted March 24, 2023 2 minutes ago, DBCooper said: Any text you put in the room label defaults just gets added after the room name. So all you need to do is get rid of the %room.name% in your defaults and leave it blank. THANK YOU!!!!! I knew it had to be something simple, not sure why I just didn't try that in the first place. Link to comment Share on other sites More sharing options...
