develospec9 Posted March 19, 2023 Share Posted March 19, 2023 Hi when I run materials list, it reports the studs in linear feet, and not the actual number of studs . is there a setting to change that will show the stud count rather than the lineeer foot? the framing is already built , and shows all the studs in the 3D and 2d view, so the program already knows this number , why wouldn’t it be reported on the materials list ? Is there an advantage to knowing the linear foot rather than the actual number of studs ? for the wall board such as OSB and drywall , it reports correctly and shows the number of sheets . That is correct . anyboby know what is going on here ?! x10 version, Thank you Link to comment Share on other sites More sharing options...
Solution GeneDavis Posted March 19, 2023 Solution Share Posted March 19, 2023 Cannot remember whether X10 had structural member reporting. Do you see it in the defaults: Tools > Materials List > Structural Member Reporting? You have to set this up (if it is there in X10) to get framing to report piece counts in your specified lengths. Link to comment Share on other sites More sharing options...
develospec9 Posted March 19, 2023 Author Share Posted March 19, 2023 Yes sir that worked , thank you for the help ))) Link to comment Share on other sites More sharing options...
PhillipCA Posted March 19, 2023 Share Posted March 19, 2023 Here is a video that reviews the different ways you can control how framing reports to the materials list using the Structural member Reporting feature. https://www.chiefarchitect.com/videos/watch/30/cost-estimating-using-structural-member-reporting.html Link to comment Share on other sites More sharing options...
