DefinedDesign Posted March 15, 2023 Share Posted March 15, 2023 Unable to remove this second room label. If I delete it, it comes back. I've tried removing all the walls and adding the walls back in and as soon as I assign a room type I get two labels. Always grateful for any insight and support. Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted March 15, 2023 Solution Share Posted March 15, 2023 Just a guess, but almost certainly being generated by the room between your foundation wall and your furring wall. Try setting those as actual furred walls in the Wall's Structure tab. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 15, 2023 Share Posted March 15, 2023 To get a non guess answer post a plan and I'm sure someone will have an answer pretty quick. Link to comment Share on other sites More sharing options...
DefinedDesign Posted March 15, 2023 Author Share Posted March 15, 2023 5 minutes ago, Alaskan_Son said: Just a guess, but almost certainly being generated by the room between your foundation wall and your furring wall. Try setting those as actual furred walls in the Wall's Structure tab. Many thanks! That corrected the issue! So appreciate you! For any new Chief users who run into this issue, here are the steps to correct: >Select the interior wall that is against your foundation wall >Open the Wall Specification >Select Structure >In the Double Wall Section Select Furred wall >Do this for each wall that is against your foundation wall. Link to comment Share on other sites More sharing options...
