Wall / Floor Problem
MathewM
I am a bit stumped on an issue with a stairwell adjacent to an exterior ICF wall.  Although it's not really exterior since there is a garage attached on the other side of it.  I suspect that is part of the problem.  If I break the wall of the stairwell, so that it is no longer a separate room, everything is good, and the room structure is correct with the floor above hung on a ledger attached to the stem wall:
975553623_Screenshot2023-03-03at3_58_08PM.thumb.png.9a4ed38987033562a05cd9cfeb4a958a.png1896625143_Screenshot2023-03-03at3_58_35PM.thumb.png.3bbba6de10fac2575be341ea6c81c210.png
If I complete the wall and create a stairwell room, the stem wall moves under the floor above and pushes the footing for the ICF wall down just where the stairwell is:
225067726_Screenshot2023-03-03at3_59_03PM.thumb.png.5054e905831ae9b8f8c75aa506bd961d.png1499429068_Screenshot2023-03-03at3_59_52PM.thumb.png.cc494908877adc92ba4ce0457a150b21.png
You can see the reason when looking at the structure for the stairwell:
 50758376_Screenshot2023-03-03at4_00_18PM.thumb.png.c1de6cb39cee56055130a4e8b0900c7d.png
Note that it is doing this even though I have "Hang floor platform above on wall" and "Subflooring to wall interior" checked for the ICF wall.  Note that if I move a wall to break the garage on the right side of that wall, that also fixes things.  Note also that there are other rooms above and below the stairwell and they do not cause this problem.  Only the stairwell.
Any ideas?
Thanks!
5 hours ago, MathewM said:
I suspect the fact that the stairwell has no ceiling above is a factor
Maybe when you are completing the room, it’s taking on prior floor elevations, from the previous plan that the current one is based on?
Ghost in the machine type of scenario.  Which is why Chief recommends using a template, especially when upgrading to a new version.
I’m just speculating, of course.
Not a bad theory.  Only thing is, before the stairwell, this was just an existing room, and its structure was fine.  So I carved the stairwell out from that room.
I think I will try deleting and rebuilding the stairwell.  If the failure occurs when I hit "Auto stairwell" which kills the cieling and marks the room above as "open below" then that must be the culprit.
FYI - Never found a good solution.  Lowering the height of the stem wall for this stairwell room fixes it.  It's not correct, but it renders correctly.  Could not find a way for the floor above to attach as a ledger rather than above the wall.
I think nobody is chiming in to help here because the problem appears too wordy, complicated to wrap our heads around, and too complex an issue to troubleshoot without an actual plan file...simply too many variables.  Most of us don't want to think that much only to play a guessing game version of whack-a-mole.  Anyway, if you were to post a plan, you would likely have a lot more good answers already.
