SantaJim Posted February 28, 2023 Share Posted February 28, 2023 New user that is attempting to trace surveyor drawing which is shown in the attached file. I imported the PDF and attempted the point to point resize and began the trace. 1) when I began the trace the line would not hold line with drag and when tab to enter the coordinate distance it would go in a different direction than the drag. 2) frustrated I enter the coordinates manually as decimal feet and quadrant bearing information (N47 57' 08" W) and so on until I achieved a closed polyline of my lot perimeter. 3) when I finished the lot perimeter turned out to be small than my resize with CA. 4) I have set to display number to display in decimal feet and quadrant bearing but I'm getting feet, inch, and fraction. The quadrant bearing text does not show as I entered it draw the perimeter. I hope that someone will be able to set me straight on what I've done wrong. Thanks in advance for the help. Using X-14 Plot Plan View.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted February 28, 2023 Share Posted February 28, 2023 Looks like you are very close and just need to set the units in General Cad Defaults. You did not embed the .pdf file into the plan though so you will need to confirm the details.. 1 Link to comment Share on other sites More sharing options...
CharlesVolz Posted February 28, 2023 Share Posted February 28, 2023 2 hours ago, Chopsaw said: Looks like you are very close and just need to set the units in General Cad Defaults. Link to comment Share on other sites More sharing options...
