mthd97 Posted February 24, 2023 Share Posted February 24, 2023 Hi, I am wondering if we have an onboard system for converting imported pdf drawings to 2D CAD lines in CA yet ? It would be good if it did have one incorporated right into the native CA work environment. What other software are you using to assist you with this process ? Thank you in advance for your replies. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 24, 2023 Share Posted February 24, 2023 41 minutes ago, mthd97 said: Hi, I am wondering if we have an onboard system for converting imported pdf drawings to 2D CAD lines in CA yet ? No 42 minutes ago, mthd97 said: It would be good if did have one incorporated right into the native CA work environment. Yes 42 minutes ago, mthd97 said: What other software are you using to assist you with this process ? https://cadsofttools.com/pdf-to-dwg-online/?sent=block Just be careful what you convert online that you are not sharing any military secrets. If you find you use it a lot, buy the stand alone software. 1 Link to comment Share on other sites More sharing options...
mthd97 Posted February 24, 2023 Author Share Posted February 24, 2023 1 minute ago, Chopsaw said: No Yes https://cadsofttools.com/pdf-to-dwg-online/?sent=block Just be careful what you convert online that you are not sharing any military secrets. If you find you use it a lot, buy the stand alone software. Link to comment Share on other sites More sharing options...
