cbucks Posted February 22, 2023 Share Posted February 22, 2023 I'm getting the following error and can't figure out what is causing this is there a good way to determine? Interpolator.cpp(395): Warning #272032197 "The terrain interpolator is ignoring terrain breaks and retaining walls due to complexity of the calculation." 02/22/2023 05:49:56 PM Build: 24.3.0.84 macOS ARM Link to comment Share on other sites More sharing options...
glennw Posted February 23, 2023 Share Posted February 23, 2023 I would not use retaining walls unless absolutely necessary. Try with only the Terrain Breaks and then use a standard wall in lieu of the retaining wall and see what happens. Best to post the plan so we can see how you are using Terrain Breaks and Retaining Walls. You may have conflicting and/or incorrect terrain data. Link to comment Share on other sites More sharing options...
