I don't want a double wall
rnmbj1906
I keep generating what appears to be double walls.  It actually looks like a normal wall within furring strips attached.  I cannot seem to remove these no matter what solution I have tried.
The wall details shows the double wall.
I have removed all wall framing.  Clicked on the wall and opened it.  Looked at the wall type and then define.  In the define area I have drywall 5/8" on exterior then the main wall of 5 1/2" stud then the inside wall as the 5/8".  I specify that the walls be 16" on center.  Then I reframe the walls and I still get the same thing - walls with extra furring strip.  Also, my walls build to 24" on center and not the 16" but the furred wall builds to 16" on center.The furred wall is 5/8" thick like the drywall.  I cannot click that separately and try to remove.
I have tried for hours on this.  Any help would be appreciated.
