dkmtek Posted February 15, 2023 Share Posted February 15, 2023 Hi all. I'm having trouble trying to delete or adjust an object? (Hole in a roof plan). I'm trying to create dormers with curved roofs (Barrels). I've gone through the videos on doing this and have a fair idea on different ways it can be done, I've created a hole in the roof plane by creating a "Polyline" and converting it to an object (Hole in roof), but now I can't adjust or delete it? I've been successful on here with two other "Dormer roofs" (Auto Floating Roof Dormers), but this one I did by creating 2nd floor walls and cutting a hole in the roof (Seems to have more control on making a dormer?). More detail: The roof is based on the first floor walls but the dormers are on the second. I can highlight the roof on the first floor plan view but when I highlight it and try to delete it, it shows up again on the 3D views? Link to comment Share on other sites More sharing options...
rgardner Posted February 15, 2023 Share Posted February 15, 2023 1.) check to make sure the roof holes layer is turned on. 2.) check for the correct level that it is on (i.e. if you put it on level 1 where the roof plane is then it will be there.) Link to comment Share on other sites More sharing options...
