DrawingABlank Posted January 25, 2023 Share Posted January 25, 2023 I created a CAD Block, set my preferred layer (not CAD Default) and then added to library. When the item is subsequently pulled from the library it reverts to the CAD Default layer. After searching, the Help files did not yield an answer or indicate any limits for CAD Block layers. This was in x14. This was reproduced in x13 so it would seem to be intentional. Seems to be a strange limitation on very basic library item. I will admit, it is possible that I am using these tools differently than intended. So... what is at play here? Operator error? Is there a better solution to have a ready made CAD 'icon' that starts on my preferred correct layer? For what it is worth, the CAD Block in question consists of a CAD circle and 4 lines. I tried changing the layers individually to the desired layer prior to creating the block and after with the same results. Thank you CAD Block Layer.zip Link to comment Share on other sites More sharing options...
Solution glennw Posted January 25, 2023 Solution Share Posted January 25, 2023 You need to change the Current CAD Layer before placing the CAD Block. Saving a cad block to the library does not save it's layer property. You also need to save and close the plan before posting otherwise there is no data in the attached plan. Link to comment Share on other sites More sharing options...
DrawingABlank Posted January 25, 2023 Author Share Posted January 25, 2023 Of course! Overriding the Current CAD layer would not make sense. I appreciate the tip on closing the file prior to uploading. Next time... Thank you Glenn. Link to comment Share on other sites More sharing options...
