How to "complete" the walls when two adjacent rooms have different ceiling heights
JBi-PDX
I've never been able to figure out how to fix this problem (which doesn't seem like it should be a problem). When I have two adjacent rooms with different ceiling heights, there is almost always gaps in the wall for the room with a lower ceiling. I've attached one screen shot showing the problem and a back-up copy of the plan file. In this particular home, there are two rooms with sloped ceilings - one tall one, one shorter, and then a bunch of 8' tall rooms. As you can see in the screen shot, there are gaps everywhere!
Any helps/tricks/notes would be great appreciated. I have this problem on nearly every drawing.
Thanks.
Jason
Appleby Backup.zip
Thanks, Eric. Signature updated. I'm sure I can get this to work now. Thanks for the tip. I rarely draw the roofs since I'm an interior designer and don't really care about the outside. But, now I know I need the roof to make all the inside walls work.
