frans21 Posted January 10, 2023 Share Posted January 10, 2023 When I download a dwg from dropbox it turns into a pdf. When I use the "save as" option it prompts me to choose between pdf, jpg or png. How can I download the dwg as a dwg? Link to comment Share on other sites More sharing options...
SusanC Posted January 11, 2023 Share Posted January 11, 2023 When I import a dwg from Dropbox, I create a new plan in Chief, and then import directly out of Dropbox. I don't download it first. When in your new Chief plan, go to File / Import Drawing dwg / browse out to your Dropbox and select the file to import. Hope this helps! Link to comment Share on other sites More sharing options...
para-CAD Posted January 11, 2023 Share Posted January 11, 2023 I share dwgs using Dropbox all the time without issue. I will check around and see if my recipients have had issues or not. Typically they just download the file and work on it in some 2D app that uses DWG/DXF Link to comment Share on other sites More sharing options...
