JKEdmo Posted January 4, 2023 Share Posted January 4, 2023 Good morning, What's the quickest way to query a room's area? Wanted to get my crawl space area shown below. I figured I'd open the Room Specification box and presto, all the data will be there under the "General" tab just like a Polyline, but no such luck. Any tips? Thanks once again, Jim Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted January 4, 2023 Solution Share Posted January 4, 2023 A few options: Select Room and click either Make Standard Area Polyline or Make Room Polyline. Open the generated Polyline, get your information from there, and then delete it. Select the Room, open up the Ruby Console, and type either owner.standard_area or owner.internal_area and then hit enter. You should see your desired information in the results. Simply turn on the Rooms, Standard Area or Rooms, Interior Area layers. Drop a text box into the room and insert either the %room.area.internal% or %room.area.standard% macros. 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted January 4, 2023 Author Share Posted January 4, 2023 14 minutes ago, Alaskan_Son said: A few options: Select Room and click either Make Standard Area Polyline or Make Room Polyline. Open the generated Polyline, get your information from there, and then delete it. Select the Room, open up the Ruby Console, and type either owner.standard_area or owner.internal_area and then hit enter. You should see your desired information in the results. Simply turn on the Rooms, Standard Area or Rooms, Interior Area layers. Drop a text box into the room and insert either the %room.area.internal% or %room.area.standard% macros. Thank you for your quick help. Jim 1 Link to comment Share on other sites More sharing options...
