Living Area SF Missing
skirby19
I deleted the LIVING AREA SF. This has came up over the years and going through the "Plan Check" has always been the solution. For some reason I can not get it back this time. Please help me figure out my mistake.
I tried to upload the .plan but it is over the 14MB limit
I'm using X14
Thank you
3 minutes ago, solver said:
Please update your signature by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left.
Thanks
Thank you. I had it correct on my profile. I did not know it needed to be done there too. Thank you for showing me.
When you select the living area and delete it, the program automagically turns it off in your general plan defaults.  If you want it back, you need to turn it back on manually.
This also means that you don't need to use "plan check" to get it back now.
