Gable to Wall Intersection
jhoney
Go to solution Solved by DavidJPotter,
I am having troubles with gable to wall intersection.  It is only happening where I have multi-pitch gables.  You can see from the pics the open triangle that is forming between the outside wall and the soffit.  I've tried everything I know to fix it.  I can make it "look" correct in 3d view by pulling down the attic wall to cover it up, but then I have the overlap lines that show up in the elevation view.  I know I can edit those lines in the layout, but I'd prefer to find a way to fix this.  Any recommendations would be greatly appreciated.  I've searched the forum and cant find  any previous posts on this specifically.
Thanks,
Justin
David,
Thanks.  I actually just found a solution.  I went in plan view and adjusted my wall layer intersections for the brick and it took care of the problem.
By the way, I watch a ton of your videos and they are extremely helpful.  Thank you for posting these and assisting all the Chief users.
