Having 3D issues
Leadcarpo
I am running into some issues. One wall has a gap in the drywall layer. There are a couple of outside corners that the drywall disappeared from. My pocket doors look like the frames are missing. When I move walls in 2d the studs stay in place and the walls don't change at all in the 3d framing view. If I try to build the framing again, it adds a bunch of "fur" strips on the walls. When I look up in the basement, it looks like there is suspended concrete in places if I turn the drywall layer off. Sorry for the rant. I am trying to fix the issues, but I am growing frustrated as well.
Wall framing doesn't rebuild automatically unless you turn on auto wall framing.  With auto wall framing off, every time you modify a wall then you will need to manually rebuild the framing.
If your framing is not building correctly, then you have probably made a mistake in the wall definition.
Your walls may not be building correctly for the same reason or maybe you have messed up the wall connections.
In any case, you will probably get better answers if you post a plan.
