Michael_Gia Posted November 15, 2022 Share Posted November 15, 2022 Hi, for some reason in one particular plan file, the point to point move tool is not able to pick up a snap point. The tool works but just by clicking on close, but random points. That is, if I click on an object I can use the tool to move the object but it doesn't recognize any snap points, both on the object nor where I'm moving the object to. Yes, object snap is on. I think I've had this issue before. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 15, 2022 Share Posted November 15, 2022 Object Snaps might be toggled on, but that doesn't mean the various types of Object Snaps aren't individually toggled off. Ares some of these that you need toggled off? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 15, 2022 Share Posted November 15, 2022 Or is it possible that you're trying to snap to one or more objects that are part of a Block? 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted November 15, 2022 Author Share Posted November 15, 2022 12 minutes ago, Alaskan_Son said: Ares some of these that you need toggled off? They are all toggled on. However, now it suddenly started working again. I wish I knew what caused this. Earlier I had tried restarting computer etc.. and still had the same problem. The only change I made prior to it starting to work again was to switch layer sets. Link to comment Share on other sites More sharing options...
