GeneDavis Posted October 19, 2022 Share Posted October 19, 2022 How can I do something like this so the window perfectly mulls next to one with plumb edge to plumb edge? And has all matching frame and sash and glass detail. Link to comment Share on other sites More sharing options...
richoffan Posted October 19, 2022 Share Posted October 19, 2022 Make the shapes out of fixed glass (much like making a trapezoid transom) and mull them all together. You could probably make that lower frame using a custom muntin. Or just make individual windows. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 19, 2022 Author Share Posted October 19, 2022 How did you do that? I go into SHAPE for a fixed window, and the only thing that seems available to get anything is the arch panel, but none of those work for me. Edit: Further exploration into SHAPE got me fiddling with the TOP INSIDE CORNER spec, and I can sort of get where I want. Why doesn't Chief let you get closer to the corner than 1/4" in either x or y? Link to comment Share on other sites More sharing options...
richoffan Posted October 19, 2022 Share Posted October 19, 2022 Don't know Gene. Many Chief "things" are a mystery to me! Some set to "0" some 1/16" and some more. I wonder if the dimension defaults for smallest fraction / decimal influence? Haven't played with that Link to comment Share on other sites More sharing options...
