RobWhite Posted October 17, 2022 Share Posted October 17, 2022 as per the attached window sill in a brick cavity wall I have created an unwanted block I have created a 1course splayed sill as per displayed in the library below, but for some reason chief is created a mould of about 25x25 (1"x1") additional moulding as the base of my sill which creates an unslightly gap below this sill. I have made sure the rough openings are set and zone The bottom sill thickness is set at 86mm (i.e. I course) Any suggestions or helps. Link to comment Share on other sites More sharing options...
rlackore Posted October 17, 2022 Share Posted October 17, 2022 Just a thought, it almost looks like what I get with these settings: Window Specification>Options>Recessed into Wall Window Specification>Sill>Use Exterior Sill>Inset>Apron IOW, is it possible that the 1x1 is the Apron? Link to comment Share on other sites More sharing options...
RobWhite Posted October 18, 2022 Author Share Posted October 18, 2022 Attached is a wall and windows with the issue initially describe. Let's know if find something Window Sill Sample.planFetching info... Link to comment Share on other sites More sharing options...
RobWhite Posted October 18, 2022 Author Share Posted October 18, 2022 So simple when you know how. Thank you. Signature updated. Link to comment Share on other sites More sharing options...
