Jeffcrigler Posted October 7, 2022 Share Posted October 7, 2022 This bath appears to work in all the 3d views, but the shower floor pan obscures shower door in working plan view. If I shrink the size of the pan I can "uncover" the door. Mystified. Upstairs South Bathroom - TOBE.plan.zipFetching info... Link to comment Share on other sites More sharing options...
Solution robdyck Posted October 7, 2022 Solution Share Posted October 7, 2022 You need to use the Drawing Order tools to control their display in plan view. No offense Jeffrey, but this plan could be used as a textbook example of how not to build a shower in Chief. If you had used an actual glass wall and an actual glass door, this wouldn't be an issue. Link to comment Share on other sites More sharing options...
Jeffcrigler Posted October 7, 2022 Author Share Posted October 7, 2022 Thanks... that worked And in my defense.... I'm a newbie at this stuff Link to comment Share on other sites More sharing options...
robdyck Posted October 8, 2022 Share Posted October 8, 2022 Glad that worked. I'd suggest you give the glass wall a try and the default glass shower door (which I noticed Chief copied from me). Also, may I suggest turning off the layer 'Walls, Main Layer Only'. This will allow the interior surface lines of the wall to display and will make it easier to place items that butt against the drywall. I'd place the shower pan on drawing order #33. That particular shower pan will need to have the stretch planes adjusted in order to be properly resized. I assume you'll be adding a bench to the back of the shower. Paste this into Help: Stretch Planes and Stretch Zones Link to comment Share on other sites More sharing options...
