Flat ceilings
Cadwork22
I created a Monitor house with lean tos.  However, the roof is at a high pitch, so the rooms on the second floor, and the rooms in the lean tos all need flat ceilings.  I've tried default settings, room settings, etc, and with no result.  Trying to get this project done which is why I'm asking for help. I have a plan file attached.  Any help would be appreciated!
Thanks!
project1.1 (1).zip
In Chief there over 11 different "Display Options" dialogs, one for plan view and one for EACH camera type individually, so if the "Ceilings" layer is off in the camera type you are using, then it would appear that one has no ceilings. When I opened your shared file, all intended ceilings were visually present. If, you were perhaps using the "Floor Camera" it is programmed to not show ceiling's by default. Take  a look and see...
