capitaldesigns Posted September 26, 2022 Share Posted September 26, 2022 Is there a way to change the spacing of electrical outlet spacing when using the auto place outlet command ? The building departments require the outlets to be placed every 6'-0" in bedrooms, living rooms, etc. and 4'-0" in kitchens. Also an outlet on walls 4'-0" and longer. Thanks, Mike Link to comment Share on other sites More sharing options...
SteveNovato Posted September 27, 2022 Share Posted September 27, 2022 I believe that bedroom outlets are 12" max. spacing so no point in the room is farther than 6' from an outlet (NEC 210.52) I have never had much luck with auto placing outlets...not much help, just my $.02 worth 1 Link to comment Share on other sites More sharing options...
