Refrigerator for small house or ADU
GeneDavis
I needed one and always make sure if making a symbol, that it is a true-scale and true-detailed one that can be sourced for real.  Doing kitchens for small houses, tiny houses, or ADUs, where space is tight, requires scaled-down appliances.
Here is a Blomberg 24" bottom-freezer fridge.  Some of their products (like their 24 inch ranges) have 3D files you can download from them to use as symbols, but this fridge was not that way.  I have their 30 inch top freezer model which uses the same door shape and handles, so I was able to model this one pretty close using info in their spec sheet.
Can you use one of these?  It is counter depth and goes into a 24 x 70 hole.  Here ya go.  Just what you needed.  A fridge symbol to blow up your plan file size.
Blomberg 24 inch bottom freezer fridge.plan
  • Upvote 2
