BIVOUAC Posted August 23, 2022 Share Posted August 23, 2022 Hi, I'm new to Chief Architect and looking for someone that can set it up for me. I use Autocad ans have graphic standards that I would like to use and layouts (different size). I also which to have typical assemblies created (walls, foundation, floor, roof, etc) and will also be seeking for materials to set-up my main products (reference to specific products). Help on workflow can be an asset. Maybe stairs options. As I am searching for services, the help is not required immediately and everything will be subject to a collaborative discussion. I need to get an idea of the budget and time I should allow. Maybe start with basics and progress along the way. Thanks a lot in advance, Chief Architect seems very interesting! Link to comment Share on other sites More sharing options...
rgardner Posted August 23, 2022 Share Posted August 23, 2022 1 hour ago, BIVOUAC said: Hi, I'm new to Chief Architect and looking for someone that can set it up for me. I use Autocad ans have graphic standards that I would like to use and layouts (different size). I also which to have typical assemblies created (walls, foundation, floor, roof, etc) and will also be seeking for materials to set-up my main products (reference to specific products). Help on workflow can be an asset. Maybe stairs options. As I am searching for services, the help is not required immediately and everything will be subject to a collaborative discussion. I need to get an idea of the budget and time I should allow. Maybe start with basics and progress along the way. Thanks a lot in advance, Chief Architect seems very interesting! I would talk to @Renerabbitt. He sells a very extensive pro version template that will save tens of hours on every job or more with newer users. He is also faster than most at setting up custom templates. Link to comment Share on other sites More sharing options...
ChiefUserFarzan Posted August 24, 2022 Share Posted August 24, 2022 Hello Sir, If remote work is an option then here is my profile for your review: https://www.upwork.com/freelancers/~01ec0012668e48dc66?viewMode=1 Thank You. 1 2 Link to comment Share on other sites More sharing options...
KAJORAD Posted August 25, 2022 Share Posted August 25, 2022 hello, kajorada@hotmail.comPortofolio Kajo Rada CHIEF ARCHITECT X12.pdf 4 Link to comment Share on other sites More sharing options...
