PMMully Posted August 22, 2022 Share Posted August 22, 2022 Using a post to beam wall, need to set the beam to a siding material like Hardie. All good but I need to change the direction of the siding on the beam from vertical to horizontal. I tried the vertical/horizontal profile setting, etc., but no results. I imaging I might have to use the surface builder stuff, I need to rotate it 45 degrees. Link to comment Share on other sites More sharing options...
Solution DBCooper Posted August 22, 2022 Solution Share Posted August 22, 2022 You just need two materials, one for the beams and one for the posts. Set the angle of the materials how you want them. 1 Link to comment Share on other sites More sharing options...
PMMully Posted August 22, 2022 Author Share Posted August 22, 2022 29 minutes ago, DBCooper said: You just need two materials, one for the beams and one for the posts. Set the angle of the materials how you want them. Ok, the define material dialog control.... got it. Thanks. Link to comment Share on other sites More sharing options...
