aurorainteriors Posted August 15, 2022 Share Posted August 15, 2022 I have a chief file I received from an architectural drafter and he has customized all of his own layer sets which does not work well for how I do my interior design sets. I've been trying to figure out how to get the settings to go back to default settings and clear out his custom settings but so far have had no success. Any suggestions? My main hang-up is my elevations- his settings turn off all finish details and cabinets and pull in different dimension defaults and I just want to use the standard kitchen and bath defaults for my elevations. Thanks, Krissy Link to comment Share on other sites More sharing options...
aurorainteriors Posted August 15, 2022 Author Share Posted August 15, 2022 16 minutes ago, solver said: Look at your options File>Import I tried that and it still is not replacing the layer sets he created or overwriting them. Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted August 15, 2022 Solution Share Posted August 15, 2022 5 minutes ago, aurorainteriors said: I tried that and it still is not replacing the layer sets he created or overwriting them. I typically do this for the horrible plans that come from Canvas I am given.......... Open one of your Preferred Plans ( your Template if you have one ) and Export everything available to a Known Backup folder for reuse... eg : C:\Documents\Chief Architect Premier X14 Data\Backups also save a copy for your Preferred Plan into this same folder , so you can import Saved Plan Views (SPVs) and Defaults ( not Default Sets) too from it. Export : Default Sets ( Annotation Sets in old-speak) Layersets Wall Definitions ( may not be needed ) Note Types On Import in to the Provided Plan make sure to Overwrite/Replace etc in each case.... Then Import the SVPs from the Preferred Plan, followed by the Defaults Mick. Link to comment Share on other sites More sharing options...
aurorainteriors Posted August 15, 2022 Author Share Posted August 15, 2022 21 hours ago, Kbird1 said: I typically do this for the horrible plans that come from Canvas I am given.......... Open one of your Preferred Plans ( your Template if you have one ) and Export everything available to a Known Backup folder for reuse... eg : C:\Documents\Chief Architect Premier X14 Data\Backups also save a copy for your Preferred Plan into this same folder , so you can import Saved Plan Views (SPVs) and Defaults ( not Default Sets) too from it. Export : Default Sets ( Annotation Sets in old-speak) Layersets Wall Definitions ( may not be needed ) Note Types On Import in to the Provided Plan make sure to Overwrite/Replace etc in each case.... Then Import the SVPs from the Preferred Plan, followed by the Defaults Mick. This did the trick! Thank you! Link to comment Share on other sites More sharing options...
