MarkMc Posted January 22, 2015 Share Posted January 22, 2015 Setting this on my toolbar- from what I can tell I need to have both "object painter" and "select properties to paint" ? IF I click "select properties to paint" first nothing happens If I select the "object painter" I get a spray can but have no control over what properties it uses If I select the OP then click properties I get a list. Is this how it works? or am I missing something somewhere? Link to comment Share on other sites More sharing options...
jcaffee Posted January 24, 2015 Share Posted January 24, 2015 This tool is turning into a real time saver! Good addition CA. jon Link to comment Share on other sites More sharing options...
ColoradoWest Posted January 25, 2015 Share Posted January 25, 2015 I came over from Softplan many versions ago and this is the one similar tool (repeat edit) they had that I really missed (about the only tool). I am so glad to see it come the CA!! Link to comment Share on other sites More sharing options...
michaelgia Posted April 28, 2015 Share Posted April 28, 2015 Still not as efficient as Softplan's "repeat edit" tool. Why do I have to hunt down a seemingly endless list of attributes and tick off what I want changed on the next item? That is, if I've just opened up the db on an item and made changes then that IS the "list" of attributes. I should just be able to click on "object painter" and then select all the like objects that I want to match. Anyone?.... Link to comment Share on other sites More sharing options...
