Qualita Posted August 6, 2022 Share Posted August 6, 2022 Hi, I have just started using chief architect. I am looking for the electrical legend but I can't find it. I have seen many videos and discussion where they show the location on the library but my version seems to not have legend. Does anyone know if it does not come on the catalogs anymore or how can I get it? Link to comment Share on other sites More sharing options...
Kbird1 Posted August 6, 2022 Share Posted August 6, 2022 It's in the Library under Arch. > CAD Blocks > Notes and legends *If you have Interiors , see my post near the Bottom too... 1 Link to comment Share on other sites More sharing options...
Qualita Posted August 6, 2022 Author Share Posted August 6, 2022 I don't have that option. No CAD blocks and no Notes & Legends. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 6, 2022 Share Posted August 6, 2022 1 hour ago, Qualita said: I don't have that option. No CAD blocks and no Notes & Legends. Then I guess you are not using Chief Architect or Interiors ? but one of the Home Designer Products which is why we ask you to fill in your Forum Signature so we can tell. If I am right you should be over Here : https://hometalk.chiefarchitect.com/ Link to comment Share on other sites More sharing options...
Qualita Posted August 6, 2022 Author Share Posted August 6, 2022 I have chief architect interiors X14. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 6, 2022 Share Posted August 6, 2022 On 8/6/2022 at 2:01 PM, Qualita said: I have chief architect interiors X14. I believe I have heard before from a Client that Interiors does NOT include the CAD Library ( no cabinet glass reflection Lines either ) and had forgotten that earlier but you can create one from an Electrical Schedule ....... Group Similar objects if you have place more than 1 of each item in a Plan , then convert the Schedule to Text and then Block it and save to your library. Assuming of course that Interiors has the above Options Comparison : x14-Premier vs Interiors-feature-matrix.pdf Link to comment Share on other sites More sharing options...
Qualita Posted August 6, 2022 Author Share Posted August 6, 2022 I create as a schedule but now I can't put it in the layout. I will figure it out. Thank you. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 6, 2022 Share Posted August 6, 2022 7 minutes ago, Qualita said: but now I can't put it in the layout. It is best to put the Schedule in a CAD Detail if possible ( assuming INT. has that option? - sorry I have never used it , only Premier ) and then send the Schedule to Layout , this gives a little more control over placement and Size , vs placing the Schedule in a Plan View and sending it to Layout with the Plan View. Mick. Link to comment Share on other sites More sharing options...
Qualita Posted August 6, 2022 Author Share Posted August 6, 2022 Ow yeah! It worked! Thank you so much!! Link to comment Share on other sites More sharing options...
Kbird1 Posted August 6, 2022 Share Posted August 6, 2022 11 minutes ago, Qualita said: Ow yeah! It worked! Thank you so much!! ....... see your PMs and Email.... Mick. Link to comment Share on other sites More sharing options...
janzen12 Posted August 23, 2022 Share Posted August 23, 2022 I'm using Interiors X14 and it would be really nice if the electrical legend was included in the Core Catalogs. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 23, 2022 Share Posted August 23, 2022 Surprised that no one is suggesting to simply use a schedule and set the parameters necessary to create your legend 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted August 23, 2022 Share Posted August 23, 2022 3 hours ago, Renerabbitt said: Surprised that no one is suggesting to simply use a schedule and set the parameters necessary to create your legend That's what 1/2 the Thread is about starting at Post #6 ...and it worked *** I have also since posting in this thread found Chief's Block is it is available in some of Chief's Sample Plans in the Gallery , eg Nashville. Austin etc ( Select > copy to your Library.) and also in the Chief Challenge Plan at the link below..... https://chieftalk.chiefarchitect.com/topic/27760-free-webinar-lighting-and-electrical-plans-ceu-credit-eligible/?tab=comments#comment-222400 M. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 23, 2022 Share Posted August 23, 2022 1 hour ago, Kbird1 said: That's what 1/2 the Thread is about starting at Post #6 ...and it worked *** I have also since this thread found Chief's Block is it is available in some of Chief's Sample Plans in the Gallery , eg Nashville. Austin etc Select > copy to your Library. M. I skimmed right past it Mixk, my apologies Link to comment Share on other sites More sharing options...
slynndesign Posted May 7, 2023 Share Posted May 7, 2023 (edited) I'm trying to represent a three-gang box with 3, three-way switches, two of them also have dimmers. I added my own text to the 3-gang switch symbol in Chief to denote this scenario. What's the best way to customize the electrical schedule if I have a custom combination? Or do I fake it and drop a screenshot at the bottom of the schedule and add my own text next to it? Or better yet…are there more electrical switch symbols I'm simply not seeing in Chief for this combination? Thanks in advance. I'm new to interiors and Chief. Edited May 7, 2023 by slynndesign adding an image Link to comment Share on other sites More sharing options...
