winterdd Posted July 21, 2022 Share Posted July 21, 2022 What's up you awesome people. Why are my porch slabs not coming in when I build the foundation? They are both checked monolithic. I am thinking this may be something easy so I'm just going to attach screenshots. Porches are built with railing walls. Link to comment Share on other sites More sharing options...
Solution DRAWZILLA Posted July 21, 2022 Solution Share Posted July 21, 2022 open those railing walls and check bearing wall and the add footing tab then re-build the foundation 2 Link to comment Share on other sites More sharing options...
winterdd Posted July 21, 2022 Author Share Posted July 21, 2022 3 minutes ago, DRAWZILLA said: open those railing walls and check bearing wall and the add footing tab then re-build the foundation ahhhhhhhh, I forgot to do that! Thanks! Link to comment Share on other sites More sharing options...
