Connect gable to hip from front to back of house
RichardUser
I think the problem may be the auto generated roof.  I have tried going to build roof, roof planes and have tried to change the section that I wanted as gables.  I also would like the main hip on the front to stretch larger than the hip behind it.  Would I need to manually make that change?
OK, like this?
It looks a bit weird with the different pitches and gables/hips.
Are they all meant to be the same pitch?
All auto roofs.
I am not quite sure about the hip on the right - can you clarify?
Hi Eric, thanks for responding.  I sent a picture (not sure if it went through) that is similar to the look we are trying to achieve.  I think I may just focus on the interior from the outline and let a professional draft the roof system.
