Emma04 Posted June 22, 2022 Share Posted June 22, 2022 (edited) I use Chief architect pro x14. Is there a way to lock wall length once done with imputing all your walls? Every time I try and use the room divider tool my wall always changes lengths; I thinks its just because of the angle I watched a video on how to fix it and was just wondering if there an option to lock your walls from the dimensions changing and not just being able to select them because of the active layer display . I'm new to Chief architect and when I used Revit it had a lock constraint next to the dimensions line, so I never had this problem before. Does Chief Architect not have this as a feature? Edited June 22, 2022 by Emma04 2 Link to comment Share on other sites More sharing options...
lbuttery Posted June 24, 2022 Share Posted June 24, 2022 Emma: don't hold your breath I have been requesting various locks such as wall locks, room locks, floor locks, wing locks etc since 2006 once I have something "done" I don't want Chief moving it because of an action I take and there is a "ripple" effect IF a lock is placed there should be a warning if Chief needs to make a change to the locked item Chief programmers believe there is no need for locks and yet the subject arises time and again Lew 3 Link to comment Share on other sites More sharing options...
