TammyO Posted June 20, 2022 Share Posted June 20, 2022 As you can guess I am relatively new to CA. I have tried to revise the information on the new layout and have screwed it up. All of my sheets are identical except for sheet number 1. I started changing it before I understood all changes needed to be made on sheet number 0. Is there a way to re-set it to default and start the process again? Link to comment Share on other sites More sharing options...
richoffan Posted June 20, 2022 Share Posted June 20, 2022 If I understand your problem you can group copy all of your changes, switch to page 0, and use edit > paste > paste hold position. Then go back to Sheet 1 and delete the sheet. Link to comment Share on other sites More sharing options...
65Shelby Posted June 21, 2022 Share Posted June 21, 2022 Tammy also, for future reference when making changes on a draft, always choose to Save As and rename the file you are working on. For example: Snell_House-001.plan Snell_House-002.plan Snell_House-003.plan This way if you ever make a mistake you can go back to a previous save and lose just a little bit of work, as opposed to the whole file. Additionally, its wise to make your default SAVE area on a cloud folder like Dropbox. This way if you accidentally delete, damage the file or get a virus the cloud account will save 15 iterations of your file. (Depending on cloud service). Redundancy and recovery should be of your highest importance. Link to comment Share on other sites More sharing options...
65Shelby Posted June 21, 2022 Share Posted June 21, 2022 Also, this thread should be moved to General. @Dermot 1 Link to comment Share on other sites More sharing options...
