Help! I screwed up my layout and need help!
TammyO
As you can guess I am relatively new to CA.  I have tried to revise the information on the new layout and have screwed it up.  All of my sheets are identical except for sheet number 1.  I started changing it before I understood all changes needed to be made on sheet number 0.  Is there a way to re-set it to default and start the process again?
Tammy also, for future reference when making changes on a draft, always choose to Save As and rename the file you are working on.  For example:
Snell_House-001.plan
Snell_House-002.plan
Snell_House-003.plan
This way if you ever make a mistake you can go back to a previous save and lose just a little bit of work, as opposed to the whole file.  Additionally, its wise to make your default SAVE area on a cloud folder like Dropbox.
This way if you accidentally delete, damage the file or get a virus the cloud account will save 15 iterations of your file.  (Depending on cloud service).  Redundancy and recovery should be of your highest importance.
