Trim Under Stairs
javachip24k
There is always a problem with under-stair walls, especially when using winder on stairs and having base molding to be continued. If you create auto generated wall under the stairway it shows without base molding. If you add a wall under it, its messing up the whole staircase and its such a time consuming way of doing it.
I know this been brought up before, but no one really has any solution how to do this. Is there an easy way to do this or video someplace showing how can this be done?.
  • 2 years later...
I agree this is annoying but I have always successfully just drawn real interior walls under the edge of a curved or straight stair object when I need base moldings to show. You just have to draw such walls carefully and correctly for it to look right, Using just unchecking the setting within the stair dialog "Open Underneath" does not produce base mold (I assume that is what you are lamenting of). So I do what does work as above.
